Re-enables an account that has been locked out (disabled) for exceeding the permitted number failed login attempts. This was configured by using the configure account [all | name] password-policy lockout-on-login-failures [on | off] command.
| all | Specifies all users. |
| name | Specifies an account name. |
N/A.
This command applies to sessions at the console port of the switch as well as all other sessions.
You can re-enable both user and administrative accounts, once they have been disabled for exceeding the 3 failed login attempts.
The failsafe accounts are never locked out.This command only clears the locked-out (or disabled) condition of the account. The action of locking out accounts following the failed login attempts remains until you turn it off by issuing the configure account [all | name] password-policy lockout-on-login failures off command.
The following command re-enables the account finance, which had been locked out (disabled) for exceeding 3 consecutive failed login attempts:
clear account finance lockout
